Arduino projects: TOP 10 NEW ARDUINO PROJECTS FOR 2020
Arduino projects have always been the center of attraction for all electronics lovers. If you are one of them then here is the list of “TOP 10 New Arduino projects for 2020” which will blow your mind.
NOTE: In this post, we have listed the Arduino projects that are most popular among the people. We select projects very carefully, keeping in mind every aspect such as the level of creativity, application, and the level of complexity of the project.
So when you go through these projects, focus on grasping the idea behind these sensors application and have fun with the tech. The Link to each project is mentioned below the respective project’s summary.
Just try out these mind-blowing projects to unleash that awesome engineer within you!
The link for the video containing the Top 10 Arduino-Sensors with Projects in 2020 is given below-
  1. Arduino Gesture Control Robot
DESCRIPTION– Experience the telekinetic power of Darth Vader with an innovative project that allows you to control your robot just with the help of hand gestures. That’s right! NO hassle of wire and controlling switches! Just a regular manual robot with an Arduino.
Components required for the project are-
  1. Arduino Nano(2x)
  2. RF Nano (optional) (2x
  3. NRF24L01+ RF Module (2x)
  4. L298N Motor Driver
  5. ADXL335 Module
  6. TT Gear Motor (4x)
  7. Rubber Wheels (4x)
  8. Male and Female Header Pin
  9. 18650 li-ion battery (2x) – (from old laptop battery)
  10. 18650 battery holder
  11. Screw Terminal
  12. Custom PCB
  13. 5mm Acrylic Sheet – (Offline Store)
Link to the project is given below-
  1. Arduino Control Robo Arm
DESCRIPTION– We understand that none of us want to touch a lot of things by ourselves or just wish to stay comfy on our work desk and let the bag of chips to come to us. Arduino Control Robo Arm allows you to do all of that. The robotic arm movements can be controlled via your mobile. Tablet or Laptop. It can do 360-degree rotation and pick things up. Mount it on top of your bot and enjoy the service.
  1. Arduino UNO & Genuino UNO
  2. PHPoC WiFi Shield for Arduino
  3. 6DOF Arm Robot
  1. Arduino Project- Self Balancing Robot
Description– This Arduino based self-balancing robot works similarly to a gyroscopic stabilizer. It senses its orientation with respect to ground and adjusts itself to stay steady. If your juice still gets spilled then it’s probably your fault.
  1. Arduino
  2. Stepper Motor
  3. A4988 Driver
  4. 10x2cm Wheels
  5. 12V Li-Po battery
  6. M5 rods and nuts
  7. HC-05 Module
  8. GY-521 Module
  1. Arduino 3D Wire Bending Machine
DESCRIPTION– This cool 3d wire bending machine is the best solution for all of your mechanical wire bending applications like a helical spring. This machine can easily create a 3D design out of a straight wire so that you don’t have to do it yourself manually by hand.
  1. Arduino Nano
  2. Stepper Motor – NEMA 17
  3. Stepper Motor – NEMA 23
  4. DRV8825 Stepper Driver
  5. Power Jack
  6. 12V 2A Adapter
  7. Micro Limit Switch
  1. DIY Arduino based Winding Machine
DESCRIPTION– This handy machine is a dream tool for electrical and electronics engineers. Arduino based winding machine allows you to make the exact number of wounds as required in a matter of seconds. Or you can make mini rolls out of the large one as per your requirement. Remember, our transformer doesn’t need to blow up just because we messed up the winding counting.
  1. Arduino Nano
  2. 96 OLED display
  3. Rotary encoder
  1. DIY Arduino camera Slider
TOP 10 ARDUINO PROJECTS FOR 2020
DESCRIPTION– Without a doubt, photography is one of the best hobbies in the world but it gets trickier when we move towards videography. A steady hand moment is a must to capture a top-notch cinematic experience. We can make it simple with the Arduino camera slider project and control the camera moments with a controlling device.
  1. Arduino
  2. Stepper Motor NEMA17
  3. A4988 stepper driver
  4. 12V 2A Adapter
  5. Joystick
  6. Power Jack
  1. Arduino Data glass for multimeter
DESCRIPTION– Arduino data glass for multimeter should be a must-have tool for all electricians out there. Working on live wires is always risky and can be life-threatening. And everyone knows that we are good only as long as we are not dry and crispy. With this cool looking safety gadget we don’t need to check for readings on multimeter. Instead, the reading will flash right in front of our eyes as we proceed.
  1. Arduino pro-Micro
  2. Bluetooth 4.0
  3. OLED display
  4. Li-Po battery
  5. Charger circuit
  6. Mirror Lens and reflector (check out the video for size requirements)
The link for the project is given below-
  1. Arduino Nerf turret
Arduino Nerf turret
DESCRIPTION– Shooting nerf turret is fun indeed. But, If you enjoy hiding in the shadows and wish to hit your opponents with precision then come on-board. Arduino nerf turret is a robot that you can control remotely and shoot nerfs while demonstrating your e-gaming skills.
The link of the project is given below-
  1. 32 Function Button Box for Gaming
DESCRIPTION– Its always fun to have more function buttons button for most of the games, especially games like Tekken where the number of combinations with a limited number of buttons can be overwhelming. But the problem is that these controllers are hard to get and expensive as well. With this project, you can build yourself your own 32 function button box for gaming and enjoy your games like a pro gamer.
  1. Arduino pro micro
  2. Switch Covers
  3. Momentary toggle, Way toggle, Start button, 3-way toggle, Push-button.
  4. Encoders
  5. Encoder knobs
  6. Soldering tools
  1. Retro Nixie Clock
Retro Nixie Clock
DESCRIPTION– last but not the least, let’s get back to the 80s with this awesome Retro Nixie Clock project. This doesn’t only make a beautiful git but also a beautiful décor to your room. A regular clock is boring to look at but you will want to check the time on this little buddy all the time.
  1. Arduino pro mini
  2. 4x IN-14 Nixie tube
  3. 4x K155ID1 Nixie tube driver
  4. LM7805 5V regulator
  5. LM7805 5V regulator
  6. DS1307 RTC
  7. SMD capacitors (1206 10uF, 100nF)
  8. Male + Female Header
  9. 4x 10KΩ Resistor
  10. 170V DC supply
  11. DC Input jack
Link of the project is given below-
If you enjoyed the top 10 Arduino projects in 2020 then
SEE MORE:
Is your PCB good enough? A PCB quality review of PCBWay!
