Arduino-Sensor Projects: Top 10 Arduino-Sensor Projects in 2020
Are you a beginner and want to work on different sensors but don’t know where to start? Here is the list of “Top 10 Arduino-Sensor Projects in 2020” for you to get started.
In this post, we have listed the most popular and widely used sensors along with a project based on each sensor. Before you go through the post I want you to know that projects listed below are selected very carefully by keeping in mind every aspect.
NOTE: Please keep in mind that the level of creativity and application is also factored in the Arduino-Sensor Projects listed below and not merely the complexity involved. So when you go through these projects, focus on grasping the idea behind these sensors application and have fun with the tech. You can find the Link to Arduino-Sensor Projects below the respective project’s summary.
Just try out these sensors to unleash that creative engineer within you!
The link for the video containing the Top 10 Arduino-Sensor Projects in 2020 is given below-
  1. Speed Regulator
DESCRIPTION– Our goal is to regulate the speed of a 5V geared motor. This is an innovative project that allows you to make a speed regulator at home using an Arduino Uno and a speed sensor. The speed sensor detects the change in the value of the 10K pot and varies the speed accordingly. Now you don’t need to worry about the low speed of fan interrupting your NETFLIX experience.
Components required for the project are
  1. Arduino Uno
  2. LM393 Speed Sensor Module
  3. 5V geared motor with encoder wheel
  4. PCB and breadboard
  5. Cables and connectors
  6. 16×2 LCD
  7. 10K POT
Link to the project is given below-
  1. Colour Sensor
DESCRIPTION- This project allows you to detect the colour of something without even looking at it. When we place a colored sheet in front of the sensor, it detects the color and flashes it on the 16×2 LCD. This project can come in handy for blind or color blind people or save your relationship when she asks you to pick up the perfect shade of Lipstick.
  1. Arduino Uno
  2. 16*2 LCD
  3. TCS-3200 / TCS-230 Color Sensor
  4. 10k Variable Resistor
  5. 220ohm resistor
  6. Breadboard
  7. Different Color Paper
  8. Some Jumper wire
  1. Temperature detector
Description- In this project, you will learn how to make a digital thermometer at home using Arduino Uno and a temperature sensor. Now you don’t need to wait for your soup to ruin before realizing that it has been burnt. All you need to do is, place the sensor near the soup. The sensor will detect the temperature and flash it onto the 16×2 LCD.
Components required for the project are-
  1. Arduino Uno
  2. LM35DZ Temperature Sensor
  3. 16×2 LCD
  4. Breadboard
  5. Cables and Connectors
  1. Alcohol Detector
DESCRIPTION- With this project you can make your handy alcohol detector at home and save yourself when your drunk friend insists on driving, claiming that he is not drunk. An alcohol detector detects the presence of alcohol present in its surrounding atmosphere and sends a signal to flash a warning message on the 16×2 LCD and set out the alarming buzzer. Congratulations! Now you are a traffic cop (almost)!
  1. Arduino Nano
  2. 16×2 LCD screen
  3. PCB
  4. MQ-2 sensor
  5. Female Header pin
  6. 10K POT
  7. Buzzer
  8. 9V battery
  9. Connecting wires
  1. PIR Sensor based Smart Lamp
DESCRIPTION- If you find flipping the light switch to be a pesky task then you can automate your house with the application of this project. You can make this project with the help of an Arduino and a PIR sensor. A PIR sensor works on the principle of thermal imaging so when it senses the presence of a human or animal body in its vicinity, it automatically sends a signal to turn the device on or off. Other than home automation, you can implement this idea to enhance your home security. Although you may need to call the cops yourself.
  1. Arduino
  2. Wi-Fi module
  3. PIR Sensor
  4. Breadboard
  5. Connecting wires
  1. Water Flow and Volume Measurement
DESCRIPTION- This project demonstrates a smart way to monitor the flow of water. The water flow sensor detects the rate of flow of water and keeps track of the total amount of water that has flowed through it. You can check the values on the LCD screen.
  1. Arduino
  2. Water Flow Sensor
  3. Breadboard
  4. 16×2 LED display
  5. Connecting wires
  6. Water pipe
  7. Transistor
  1. Gas Detector
DESCRIPTION- Keep your hose and neighbourhood safe from blowing up with this simple and economical project that alerts the user if there is any gas leakage in household premises.
The gas sensor in the circuit detects quickly senses the butane gas which triggers an alarm in the circuit along with the message signal sent to the owner over the internet.
  1. Arduino Nano
  2. MQ2 gas sensor
  3. 220 OHM resistors 2 nos
  4. Red and Green LED
  5. 9V battery and clip
  6. Buzzer
  7. Breadboard
  8. Cable and Connectors
The link for the project is given below-
  1. Automated street light project using LDR
DESCRIPTION- With this project, you can automate your street lights and save yourself the trouble of stepping out at night. LDR sensor detects the absence and presence of light. When the sun goes down it sends a signal to reset the relay and complete the circuit.
  1. Arduino
  2. LDR sensor
  3. 1K resistor
  4. 1N4007 Diode
  5. BC547 Transistor
  6. SPDT relay
  7. 10K POT
  8. Bulb
  9. Bulb holder
  10. Connecting Wires
The link of the project is given below-
  1. Soil Moisture Monitoring
DESCRIPTION- Now you don’t need to worry about killing your plants anymore. With soil moisture monitor you can monitor the volumetric content of water in the soil. The sensor detects the moisture level and displays it onto the LCD screen so that you could know how much water you need to give to your plants.
  1. Arduino
  2. Soil Moisture Sensor Module.
  3. 16×2 LCD
  4. Some Jumper Wires
  5. 10k Potentiometer
  6. Bread Board.
  7. Connecting wires and cables
  1. Ultrasonic sensor LED Project
DESCRIPTION- This is my personal favorite among all other Arduino-Sensor Projects. This project allows you to detect the distance of an object or person from you. The ultrasonic sensor sends an ultrasonic signal with bounces back to it from the surface of the object. Based on the time taken by the signal it calculates the distance of the object from the sensor. Multicolour LEDs demonstrate the distance of a person or object. So now you can make sure that your ex and kidnappers don’t sneak up on you from behind.
  1. Arduino Uno
  2. Ultrasonic sensor Hc-sr04
  3. 7 x LEDs
  4. 7 x 220ohm resistor
  5. Breadboard
  6. jumper wire
Link of the project is given below-
SEE MORE:
For more Arduino projects click on this link
Arduino Projects for beginners (7 Great Arduino projects with Code in 2020)
Or check out TOP 10 New Raspberry pi Project ideas in 2020
Raspberry pi Projects: TOP 10 New Raspberry pi Project ideas in 2020
