7 Best Capacitor Kits of Every Type(Electrolytic, Ceramic, SMD)
Capacitors have a wide application in electronics. There are several types of capacitors, i.e., ceramic, tantalum, aluminum, film, etc, available in the market. It becomes essential to have a capacitor kit in each category if you frequently do projects or repair work. We have compiled a list of the best capacitor kits available in the market for particular types of capacitors. The list has been carefully made by industry experts considering all the essential factors.
List of Best Capacitor Kits
Best Aluminum Electrolytic Capacitor Kit Buy on Amazon
Best Ceramic Capacitor KitBuy on Amazon
Best Tantalum Capacitor Kit Buy on Amazon
Best SMD Ceramic Capacitor KitBuy on Amazon
Best Film Capacitor KitBuy on Amazon
Best SMD Electrolytic Capacitor Kit Buy on Amazon
Best Trimmer Capacitor KitBuy on Amazon
This is the best ceramic capacitor kit with a total of 300 capacitors and 30 different capacitance values. Each capacitor set is provided in a separate plastic box. To avoid confusion, the capacitors in the picofarad range are placed in a yellow box, the nano-farad range capacitors are placed in a blue box, and the microfarad range capacitors are placed in a red box.
  • Material: Ceramic
  • Number of components: 300
  • 10 Capacitors each of capacitance values ranging from 0.1uf to 680pf
  • Separate plastic compartments for each value of capacitors
  • Yellow box for pF, Blue box for nF, and Red Box for uF capacitors
  • Multilayer monolithic ceramic coating
This kit on the list also has ceramic capacitors, but they are of the SMD type. They come in the shape of a strip. You have to simply pull off the plastic strip on the capacitor and mount it directly on your circuit. The values on the stripes are handwritten, so you might have to organize your kit as soon as you get it to avoid any further confusion.
  • Material: Ceramic
  • Mounting type: Surface Mount
  • Number of components: 720
  • Capacitors ranging in value from 10uF to 1 pF
  • Capacitors with 36 different capacitance values
  • 20 pieces of capacitors of each value
  • All capacitors are tested for stability, reliability, and consistency
  • 6-month refund policy
  • Very helpful customer support
These Aluminum capacitors by Bojak have a high quality and longer life than the other competitors. This is a really great kit, as you are getting more than 600 capacitors at a very low price. This kit even contains capacitors with the same capacitance values but different operating voltages. It is perfect for DIYers and electronics repair shops.
  • Material: Aluminum
  • Shape: Round
  • Maximum Operating Voltage: 50 Volts
  • Capacitance Tolerance: ±20%
  • Operating temperature: -40℃ to 105℃
  • 24 different values of capacitors
  • Compartmentalized plastic box for storage of capacitors
This tantalum capacitor kit has a total of 100 pieces with capacitance values ranging from 1uf to 100uf. They have a higher electric field strength and Equivalent Series Resistance (ESR) than most tantalum capacitors available in the market. The capacitors in this kit are packed in a plastic storage box with different compartments for each capacitor value.
  • Material: Ceramic
  • Number of components: 100
  • Maximum Operating Voltage: 16 Volts
  • Capacitance Tolerance: ±10%
  • 10 capacitors each of capacitance values ranging from 1uf to 100uf
  • High electric field strength
  • High ESR
Best Electrolytic Aluminum Capacitor Kit
This capacitors kit by Walfront uses premium quality materials so that the capacitors have a longer lifetime. This kit has 400 different capacitors with capacitance values ranging from 1uf to 1000uf. They have a higher operating temperature range than most capacitors on this list. However, the error in capacitance is also high for these capacitors, i.e., ±20%.
  • Number of components: 400
  • Shape: Round
  • Capacitance Error: ±20%
  • Capacitors have a very thin dielectric oxide layer which ensures they have a higher capacitance voltage
  • The anode surface of these capacitors has been enlarged
  • Capacitors with 24 different capacitance values ranging from 1uf to 1000uf
  • Maker code on each capacitor for easy identification
  • Comes with a compartmentalized plastic box for separate storage of capacitors with different values
This kit contains film capacitors with capacitance ranging from 0.22nf to 470nf. They are made of high-quality material and hence their capacitance deviates by a very small value, i.e.,±5%. The maximum operating voltage for these capacitors is 100V.
  • Material: Polyester
  • Number of components: 700
  • Maximum Operating Voltage: 100 Volts DC
  • Capacitance tolerance: ±5%
  • Operating Temperature: -40℃ to 85℃
  • Pin length: 0.8 inches
  • Capacitors ranging from 0.22nf to 470nf
  • Comes with a robust plastic box with separate compartments for different values of capacitance
This capacitor kit from Honbay consists of trimmer capacitors. Though this kit has only 30 pieces with capacitance values ranging from 5pf to 60pf, their quality is far better than the other types of capacitors. The operating conditions of these capacitors are well-suited for most applications. A screw to change the capacitance value is not provided, so you’ll have to get it separately.
  • Material: Plastic
  • Maximum operating voltage: 100 Volts DC
  • Operating Temperature Range: -25℃ to 85℃
  • Size: 0.24 x 0.22 x 0.31 inches
  • 30 pieces each ranging from 5pf to 60pf
  • Pin space: 5 mm
  • Insulation Resistance: 10,000 MΩ
  • Color-coded capacitance values with 5 pieces of each value
  • Blue is 5pf, white is 10pf, red is 20pf, green is 30pf, yellow is 40pf, and brown is 60pf
Conclusion- Best Capacitor Kits
All kits on this list are vetted by professionals, so you can buy them with your eyes closed. All you have to do is select the right kit for your project. Take into consideration the capacitance values, capacitance tolerance, operating voltage, working temperature range, etc., of the capacitors before making a purchase. This article has thorough information on all these aspects, which will help you make a well-defined decision.
