Electrical Wires | Electronics Course (Chp 1 Lesson 7)
Every electronic circuit, no matter how simple or complex, needs a way to connect its components together. Whether you’re connecting a battery to an LED or building an ESP32 project, you’ll use electrical wires to carry current from one component to another.
ABC OF EVERYDAY ELECTRONICS
Lesson Locked
Electrical Wires
⏱ 5 min 16 sec • Chapter 1 • Lesson 7
Although wires may seem like simple pieces of metal, they come in different materials, sizes, and constructions. Choosing the right wire makes your circuit safer, more reliable, and easier to build.
In this article, we’ll learn what an electrical wire is, the materials used to make it, the different types of wire, and how wire thickness affects the amount of current it can safely carry.
What is an electrical wire?
An electrical wire is a conductor used to carry electric current from one point to another.
Most electrical wires consist of two parts:
  • Conductor – The metal core that carries the electric current.
  • Insulation – The outer plastic coating that prevents electric shock and protects the conductor from damage.
When you look at the charging cable of a phone or laptop, the colored outer covering is simply insulation. The actual conductor is hidden inside it.
Without this insulating layer, touching a live wire could be extremely dangerous.
Why are some wires thicker than others?
Take a look at a smartphone charging cable and compare it with the power cable of a laptop or an electric heater. You’ll notice that the laptop cable is usually much thicker.
This isn’t just for durability or appearance.
Thicker wires have a larger cross-sectional area, which gives them lower electrical resistance. Lower resistance means less heat is generated when current flows through the wire, allowing it to safely carry more current.
Thinner wires have higher resistance and are suitable only for lower current applications. This is why high-power electrical appliances use thicker wires than low-power electronic devices.
Resistance of a wire
Like every conductor, a wire has some electrical resistance.
The resistance of a wire depends mainly on three factors:
  • Length of the wire
  • Cross-sectional area
  • Material of the conductor
A longer wire has higher resistance because electrons have to travel a greater distance. A thicker wire has lower resistance because it provides a larger path for current to flow.
The relationship is given by:
R = ρL/A
where:
  • R = Resistance
  • ρ = Resistivity of the material
  • L = Length of the wire
  • A = Cross-sectional area
This is why thicker wires are preferred whenever large currents need to be carried.
Wire gauge
The thickness of a wire is specified using its wire gauge. One of the most common standards is American Wire Gauge (AWG).
An important point to remember is that wire gauge works opposite to wire thickness.
  • Smaller AWG number → Thicker wire
  • Larger AWG number → Thinner wire
For example, a 12 AWG wire is thicker than an 18 AWG wire and can safely carry more current.
If you’re building electronics projects, you’ll commonly encounter jumper wires and hookup wires in the 22–26 AWG range.
Solid core vs stranded wire
Electrical wires are available in two main forms.
Solid core wire
A solid core wire consists of a single solid conductor. These wires are inexpensive, hold their shape well, and are commonly used for breadboards, PCB prototypes, and fixed wiring where the wire is not expected to move frequently.
However, repeated bending can eventually cause a solid wire to break.
Stranded wire
A stranded wire is made up of many thin strands of wire twisted together.
Although both solid and stranded wires may have the same overall thickness, stranded wires are much more flexible and can withstand repeated bending without breaking.
For this reason, stranded wires are commonly used in charger cables, USB cables, appliance wiring, robotics, and most practical electronics projects.
Materials used for electrical wires
The conductor inside a wire can be made from several different metals.
Some commonly used materials include:
  • Copper
  • Aluminum
  • Silver
  • Gold
  • Steel
  • Iron
Among these, copper is by far the most popular because it offers an excellent balance of electrical conductivity, flexibility, strength, and cost. Aluminum is also widely used, especially in power transmission and some household wiring, because it is lighter and less expensive than copper.
Although silver has the highest electrical conductivity of all metals, its high cost makes it impractical for most wiring applications.
When selecting a wire for an electronics project, consider the following factors:
  • Current the wire must carry
  • Flexibility required
  • Operating voltage
  • Type of application
For breadboard circuits, solid-core hookup wires are usually the best choice because they fit securely into the breadboard.
For projects involving movement, such as robotics or portable devices, stranded wires are generally preferred because they are much more flexible.
Summary
Electrical wires provide the path through which electric current flows in a circuit. Every wire consists of a conducting core surrounded by an insulating layer that protects both the wire and the user.
The thickness of a wire directly affects its resistance and current-carrying capacity. Thicker wires have lower resistance and can carry higher currents, while thinner wires are suitable for low-current electronics.
Finally, wires are available in both solid-core and stranded forms. Solid wires are ideal for breadboard prototyping, whereas stranded wires are more flexible and are used in most real-world electronic devices.
