Lithium-ion, or Li-ion, batteries are the most widely used rechargeable batteries today. They power everything from smartphones and laptops to cameras, power tools, drones, and even electric vehicles.
Lesson Locked
Their combination of high energy density, lightweight construction, and long cycle life has made them the preferred choice for most portable electronic devices.
Why are Li-ion batteries so popular?
Compared to older rechargeable battery technologies, Li-ion batteries offer several important advantages.
One of their biggest strengths is their high energy density. This means they can store a large amount of energy while remaining relatively small and lightweight.
For example, a typical lithium-ion battery can store around 150–250 Wh of energy per kilogram, depending on its design and chemistry. In comparison, a Nickel-Metal Hydride (NiMH) battery typically stores around 60–120 Wh/kg, while a lead-acid battery usually stores only 30–50 Wh/kg.
This is why smartphones, laptops, and other portable devices can run for many hours without requiring large, heavy batteries.
Advantages of Li-ion batteries
Lithium-ion batteries have several advantages over older rechargeable battery technologies.
Some of their key benefits include:
- High energy density
- Lightweight construction
- Low self-discharge
- No significant memory effect
- Hundreds to thousands of charge cycles
- Relatively fast charging
These advantages have made Li-ion batteries the standard choice for most modern portable electronics.
Nominal voltage
Another advantage of a lithium-ion cell is its nominal voltage of about 3.7 V.
This is significantly higher than the nominal voltage of rechargeable Ni-Cd or NiMH cells, which are typically rated at 1.2 V per cell.
Because each Li-ion cell provides a higher voltage, fewer cells are often required to achieve the desired battery voltage.
Battery Management System (BMS)
Unlike many older battery technologies, lithium-ion batteries require careful monitoring during charging and discharging.
For this reason, most lithium-ion battery packs include a Battery Management System (BMS).
The BMS monitors important parameters such as:
- Battery voltage
- Charging and discharging current
- Temperature
- State of charge
It also helps protect the battery from overcharging, deep discharge, overheating, and short circuits, making lithium-ion batteries much safer and improving their overall lifespan.
How can you increase the lifespan of a Li-ion battery?
One common question is how to make a smartphone battery last as long as possible.
Although modern phones automatically manage battery charging, a few simple habits can help reduce battery wear over time.
Avoid frequent deep discharges
Unlike Ni-Cd batteries, lithium-ion batteries do not suffer from the memory effect. There is no need to completely discharge the battery before charging it again.
In fact, lithium-ion batteries generally prefer partial charge and discharge cycles. Frequently allowing the battery to reach 0% can slightly accelerate battery aging over time.
Avoid prolonged exposure to high temperatures
Heat is one of the biggest factors that reduces the lifespan of a lithium-ion battery.
Leaving a phone in direct sunlight, inside a hot car, or using it heavily while charging can increase battery temperature and speed up battery degradation.
Don’t worry about charging frequently
Modern smartphones are designed to be charged whenever needed.
Charging the battery from 40% to 80%, for example, is perfectly fine and does not damage the battery.
Do Li-ion batteries last forever?
No.
Like all rechargeable batteries, lithium-ion batteries gradually lose capacity as they age.
Every charge and discharge cycle causes a small amount of wear, so after several hundred or even thousands of cycles, the battery will no longer hold as much charge as it did when new.
Even if a battery is rarely used, it slowly ages over time due to natural chemical changes inside the cell.
