A Raspberry Pi is a small single-board computer. With the help of it, we can do things as simple as blinking an LED to controlling big robots. It enables people of all ages to explore computing and learn different things. But before every complex design, every twisted structure of programming involved in a project, there comes an idea to create something new, to update something existing, or to take something to the bee’s knees.
So keeping that ‘idea’ in mind, we have selected the Top 10 Raspberry Pi projects for you.
Mentioned below are the individual projects along with the video link.
10. LED World Clock
OBJECTIVE:
An innovative project that takes a simple wall clock to the next level. Along with time and date, it also shows the weather of the current location. For fun purposes, a snake game is also programmed in this clock. This time, every five minutes the clock updates itself moreover, you can see the display in random words spread across the clock.
Components required for the project are:
- Raspberry Pi
- RGB LED Strip
- Breadboard
- Push Buttons
- Connecting Wires
- Op-Amp
- Power Source
Check out the video below to learn more about the above project:
9. Cutie pie Tablet
OBJECTIVE:
It’s a smart tablet powered by the Raspberry Pi. An easy and convenient way to give your imagination, the power to be accessed from anywhere. It has a wider display, a portable handle, and long battery life, therefore, you can use this tablet even when traveling. In spite of all this, the compatibility of the original Pi environment is maintained.
- Raspberry Pi
- PCB board
- Wi-Fi Module
- Bluetooth Module
- Amplifier
- Gyroscope
- STM 32 MCU
- Power Supply
You can find the link to the above project below:
8. Sense Hat
OBJECTIVE:
A simple and innovative project to display any information on an 8×8 LED matrix. It can also provide the temperature, pressure, and humidity readings of a location. In addition, the gyroscope and five-way joystick can be used to control and also play games like snakes, Tetris, flappy astronauts, and other shooting games.
- Raspberry Pi
- Sense Hat
- Screws and bolts
- Power Supply
7. Home Security System
OBJECTIVE:
It’s a simple and economic project to protect your house from theft or robbery. This project detects when a door is tried to open, if the user does not input the correct pin in a given period of time, it raises an alarm along with an e-mail notification sent to the owner of the house. In conclusion, this project keeps you safe at an economic rate.
- Raspberry Pi
- Breadboard
- LED
- LCD Screen
- Switch
- Buzzer
- Keypad
- Resistors
- Connecting Wires
6. Analog Music Player
OBJECTIVE:
It’s a cool project that gives the feel of an old electronic boom box with the modern raspberry pi controller. Interestingly, this music player has actual buttons to play/pause a song, switch to the next song, mute, repeat, and dim. It has a potentiometer to adjust the volume and a motorized fader which moves from left to right as the song plays. How cool is that?
- Raspberry Pi
- Touch Screen Display
- Power Adapter
- Push Buttons
- Toggle Switch
- Motorised Fader
- Potentiometer
- Motor Controller
- Analog to Digital Converter
5. Geiger Counter
OBJECTIVE:
An interesting project that counts the radiation level along with a ticking sound as we bring any radioactive material close to the Geiger counter. Moreover, even after turning the power is OFF, the meter retains the counts. Furthermore, We can turn The ticking sound ON/OFF via the toggle switch provided in it.
- Raspberry Pi
- Motor
- Motor controller
- Toggle Switches
- Counter
- Screws and bolts
- Power Supply
- Buzzer
4. Micro Quadruped Project
OBJECTIVE:
This project demonstrates two modes of controlling a quadruped robot. The first mode also called ‘Trot Gait’ involves the motion of two legs at a time. The second mode also called ‘Walk Gait’ involves swing of one leg at a time with body shift in between for balance. you can control both these modes via keyboard.
- Raspberry Pi
- Battery
- Servo Motors
- PWM Board
- LCD Display
- Connecting Wires
- Push Buttons
3. Inspirational Messenger
OBJECTIVE:
A simple and creative project that displays a random motivational quote every morning. In fact, In addition to that, you can see any message or remainder on the display at the predefined time. Since the device is connected to the cloud, you can download the required information to the device.
- Raspberry Pi
- Display Screen
- Adapter
- Micro USB PCB
- Connecting Wire
2. Cryptocurrency Hardware Wallet
OBJECTIVE:
With this simple project, we can store, transact bitcoins, and also do other cryptocurrency assets. First of all, we create a wallet along with a private key. Along with that, we require a PIN to enter the wallet. The numbers rearrange in the display every time the user logs in.
- Raspberry Pi
- LED Screen
- Push Buttons
- Adapter
- Header
- Screws and Bolts
1. GOTO Telescope
OBJECTIVE:
Firstly, we will use an ordinary 8-inch telescope along with the raspberry pi telescope to find the exact location of any celestial body in space. Secondly, through push buttons and a toggle switch, we will select a particular planet, star or constellation from the monitor screen and the telescope will automatically track it across the sky.
- Raspberry Pi
- Telescope
- Monitor Screen
- USB Cables
- USB Hub
- Camera
- Joystick
- Pushbuttons
- Toggle Switch
- Connecting Wires
- Power Supply
You can also watch all the projects mentioned above in one video:
